Which Bolts
Chorlton
Which Bolts
Post by Chorlton »
As Im replacing the Inlet manifold on my beast and seeing as the existant bolts are already rusting is it worth replacing them with some of the stainless beasties seen on Ebay?
katanaman
Post by katanaman »
you can but be warned a lot of the kits on ebay are for the buick engine so some are no where near fitting the rover. The front cover/water pump are the main wrong ones but they can also not fit the inlet depending on which one your using.
Post by CastleMGBV8 »
Real Steel do nice sets in stainless for both the inlet and exhaust.
Chorlton
Post by Chorlton »
Thanks for that gents
