Hello, what is the best manifold for a rover v8 with a 4 barrel carb? I have the offy type but been told its not all that good. Its being used with a holley. Has anyone any opinions? Also is it worth using a single plane manifold over a duel plane?
Thanks.
Which inlet maifold for a carb rover?
- Andy515666
The Edelbrock is a good one to go for but be aware that the ports will only match up to a standard head. If you head has been gas flowed you should open up the runners in the edelbrock where they meet the heads.
The ali is quite soft so this can be done with a dremel and hand files, it still takes a while though!
In fact I found that the edelbrock does not even match up to the standard ports very well, there can be a step of 3-4mm on some ports.
I bet all the other manifolds are just as bad though.
Pete
Pete
