measurement please
bodger
measurement please
Post by bodger »
can anyone tell me how long the SD1 LT77 bell housing is please :
IE: from engine to box ?
thankyou ..
davemgb
Post by davemgb »
RPi website says 18.5mm which I suspect should have been typed as 185mm.
This seems a little short to me but I don't have a bell housing to hand at the moment. I'll check in the cold harsh light of day...
Oh, this is presumably for a sportscar/SD1 since I know the four wheel drive housings are somewhat longer.
EDIT:-
Saturday afternoon now and I have measured up - 180mm.
Post by ian.stewart »
from memort , around 171mm
THE SMOKING GNU
tetlow
Post by tetlow »
180mm
1973 MGBGT
1975 MGB V8
I thought I could see the light at the end of the tunnel but it turns out it was a train comming!!
bodger
Post by bodger »
thanks guys ...i was hoping to use my existing bell housing ( a series one with adaptor ring ) but it's nearer 220mm
i have an old 2.0 ltr sherpa box on there and i was going to replacit with an lt77
bodger
Post by bodger »
Hello again , plan B ...now
can anyone tell me the total length from front of bell housing to output flange please ?
chrismc
Post by chrismc »
From the front of the bellhousing to the output flange- 670mm.(approx)
bodger
Post by bodger »
thankyou Chris
bodger
Post by bodger »
more measurements please ...
LT77 , front end
= from front face to the end of the input shaft
= from front face to end of splines
= from front face to end of thrust tube
= diameter of the splines ..24.9 or 25.4 ? it is 23 splines
and the length of the spigot tip
please gents
