B&M SHIFTER
Marsho
B&M SHIFTER
Post by Marsho »
Hi, has anybody fitted a B&M shifter to a GM gearbox as fitted to the rover sd1, if so what modifications where required as I believe its not a straight forward fit, ie is it easy , difficult ? any help appreciated thanks, David.
MARSHO
andyv8van
Post by andyv8van »
i have a hurst shifter fitted to my BW65 box in my mini.i had to make a new shift arm for the box.it matches the shifter cable movement to the throw of the arm radius.
Andy
3.9 V8 Mini Van....THE BEAST
Marsho
B&M SHIFTER
Post by Marsho »
Hi Andy thanks for the reply, what actually pushes the lever on the box into position?if it was rod activated I can see it working , or is the cable supported /short enough to operate without any kinking in the cable, thanks David.
MARSHO
The cable on my b&M is more like stiff wire as opposed to a braided cable.
As long as its clamped at the shifter and clamped at the gearbox end it does the job of pushing and pulling just fine.
Marsho
B&M SHIFTER
Post by Marsho »
Many thanks for the reply it makes sense now, I should be able to sort that out (thats after I find a gearbox) regards David.
MARSHO
andyv8van
Post by andyv8van »
hi,
what gearbox are you looking for?just removed a BW65 from my van
Andy
katanaman
Post by katanaman »
Going by the OP its a GM box he wants not a BW
Marsho
B&M shifter
Post by Marsho »
Hi , thanks for the offer but its a GM box I am after , by the way what torque converter do you use? regards David.
MARSHO
