'PULSAIR' - Rover V8
What's it do exactly, does it work, and can I ditch it and blank off the holes!!!!
It was an emissions thing. You can remove (probably works better as a result!).
You can buy bolts to block the holes off but they are quite tricky to find. If you look at past threads, there is someone on here who can supply them.
Other alternative, as I did, is to remove the pipes and then weld up the top of the plugs that go in the cyliunder head (having removed them first
just picked up my rover v8 and it has the air pipes on,
this is the first rover v8 i've owned and was surprised to see them fitted,
i've always been a small block chevy guy and lots of them had AIR fitted,
so, my question is, what cars were they fitted to?
the head number is :
erc 0216 x
4 e652
it also has zenith carbs on it,
thanks,
neil
erc 0216 x
4 e652
thanks,
neil
