Well I got a bit done today, but not as much as I'd hoped. As usual when building anything the time seems to be taken up more with measuring and mocking up than final assembly. Waking up at midday with a steaming hangover didn't help much either..
A trip to the local homebase yeilded a sheet of 18mm MDF for £23. Now I know homebase is not the cheapest for this kind of thing but they got a great cutting service there that I had to take advantage of. I planned out all my cuts on a piece of graph paper and got the guy there to cut it to my spec. First two cuts free, 50p each thereafter. I can't emphasise enough the grief you can save by using this service. If you haven't got at least a table saw at home then you just can't get close to these results. Total spend now £138.
Here I messed about with an offcut getting the circle just the right size for the motors. I wanted an slight interference fit to support the motors so after about 3 goes with the compass I got what I wanted, a hole just slightly too small that I could then finish off with a flap wheel. Better to fiddle around like this than cut a slightly too big hole in the work piece and have to junk it. As you can see i've left space in there for two more motors in the future if I decide that I need them. That would probably mean building a new box, but at least I know I could keep the same dimensions and thus keep upheavel to a minimum if I did go that route. I think four motors should be enough though.
The precisely cut MDF went together first time dead snug, with no fettling required. Lovely. Anyone who's ever built a subwoofer box will be familiar with this kind of build. I've lined it all up and tacked it together with some screws here, in the week I shall glue it up and countersink all the screws for a nice finish and also cut a hole for the exhaust side of the box. The motors will be glued and sealed in firmly and smear of sealant around all the joins for added sealing before the lid goes on.
I am still debating the wiring of the motors and the current plan is to wire them in two pairs, with one pair on a delay starter. The circuit should be well up to this but the motors are rated at 1400w each so best to be on the safe side. Anyone out there who would like to comment on the wiring for these? I would welcome suggestions, for example would it be possible to wire each pair of motors in series? would there be any point in doing so?
Hope to finish the pump this week, will post any progress
