Scimitar rear axle
misterb
Scimitar rear axle
Post by misterb »
I'm interested in comments, suggestions and views of my choice of axle for my Rover V8 powered MGA, project, which is a H4A axle from a Reliant Scimitar.
The reason for this choice went as follows:
The right ratio at 3.07
Strong enough to cope with power
Correct PCD for MG
Existing four link/coil over set up.
...and it came at the right price!
But here's my dilema - it is 2 inches wider than required and needs this taken from the near side casing/shaft, to centre the pinion to fit the MGA.
Before I shell out for narrowing and new halfshafts etc, I appreciate members views/experiences with the axle and potential problems (I plan to convert the 'A' to 4 link coil over set up as well).
One day it will be finished!
katanaman
Post by katanaman »
I am guessing its from a 5A so should have the modern seals although its still old fashioned in the taper mount hubs that are a sod to get off. Its also likely to be a bit worn a tired so allow for a diff rebuild. Bearings are easy to come by but the crown and pinion arent. The seals are likely to be knackered as well because of the stupid breather arrangement that gets blocked. The tubes and 4 link metal work can suffer from tin worm so give this a check before you hand over the cash. If your not planning on a rear disk conversion check the drums as they crack and they are £80-£90 each. Last but not least its a heavy old chunk of iron but is fairly strong.
The 3.07:1 is a bit odd as their normally 3.37 for the manual and 2. something for the auto. Are you sure this is right as it might point to it being from an SE6 which means its a lot wider than you think. Course it could have had bits swaped around.
kev_the_mole
Post by kev_the_mole »
...the pipe and slippers brigade aren't gonna be happy! :D :D :D
katanaman
Post by katanaman »
Stuff them, cars were made to be modified :wink:
misterb
Post by misterb »
No, they aint - but I've not been chucked out of the register yet!
Anyway thanks for comments Marki,
I've had the axle for sometime, its definitely the narrow one and I was fairly sure of the ratio but will check again. I got it from a guy I know who acquired a complete rolling chassis with a Scimitar he purchase off e-bay. I've checked the ring gear and although I'm no expert, it looks pretty good to me, very clean with little wear pattern (I took the view that it may have had a recent rebuild, although the front seal leaks). The weight, the grief of removing the hubs, along with the narrowing issues are the reasons I'm having second thoughts.
Apart from going the independent route, the other option would be MGB, with V8 gears.
Also, does anyone know a company who can narrow this axle?.
kev_the_mole
Oh I agree :D
....but I picked up my second Fatwah at the Wessex show on Sunday.
Boiling a long (boring) conversation with a 'gentleman' down to just a few words it went something like this ....
"If you want to fiddle with cars young man why don't you get a Caterham or one of them kit cars rather than ruin an irreplaceable '50's icon"
.... then didn't like it when I pointed out his car was painted in a non-original colour, that with his attitude he'd have to get rid of his electric fan, contactless ignition and lead-free head. Obviously he liked to fiddle as well.
Anyway I can't join his group. (They only have one good road run a year so it's not the end of the world)
Mind you the NSRA boys also have problems with me :D :wink:
Mention that you have a heavily modified 50's car with a Chevy lump and axle and watch the smile on their faces fade as you tell them it's a sports car. Any americans, anglo-american hybrids, classic british tin except a sports car where they seem to be blindsided as it being 'not quite right'.
It's discrimination, that's what it is!!! Perhaps I can get a lottery grant :lol: :lol: :lol:
ihatesissycars
Post by ihatesissycars »
In that situation my argument has always gone towards "well if I hadn't of given a new lease of life to the car would it still be here?"
Or "listen to this!" cranks engine "oh well yes that is most agreeable!"
katanaman
Post by katanaman »
The front seals always leak lol, if it doesn't then it finds its way along the pinion thread unless it has sealer on it. The older ones were even better as they had leather seals which were totally US.
Is the axle width too much or could you get away with a different offset on the rims? Thereby moving the outer rim position inboard
misterb
Post by misterb »
Hi Ian,
I was hoping that this would be the case, as its only 1 inch (bigger) on each side but the 'A' needs to have the pinion bang in the centre of the chassis and on the Scimitar axle its offset.
kev_the_mole
Just found this if you're looking for ideas :D
Can be found somewhere on www.britishv8.org.
Dont worry you MG boys.
I've got an MGB V8 with a Chevy auto trans, Al6, Mallory electronic stuff, Weber 500, WON nitrous system, lots of gauges ,bells and whistles. The MG owners club love it.
Mind you, when I go to Bromley not many of the Tartan rug and picnic basket MG mob want to talk to me. And the V8 register seem a little stand offish when I go to Silverstone.
But what the hell!!
Build it, test it, rag it.....
PS
Hauser rwcing will do axle narrowing. I dont know where you are, but they are in Northampton area.
v8viva
Post by v8viva »
Hi...this is the axle i am using in my V8 HB viva
I have had a jag powerlok diff machined to fit and it has been 4 linked with a panhard rod.Rear brakes have been converted to sierra cossie discs.
Seems to be just the job so far and handled its first burnout nicely lol
www.youtube.co.uk and check out HB viva v8
If at first you dont succeed.....destroy all evidence that you tried!
v8viva
Post by v8viva »
PS
Now in Finedon northants...the hot bed of all things V8 lol
Forgot to say John sharp at john sharp engineering is the man to talk to on modifying scimitar axles.He is based leicester way and i'm sure he has his own website
magpies
mga axle
Post by magpies »
just googled and john sharp engineering is on 01162 416287
building a scimitar to rally / sprint / hillclimb
