Hi again everyone
Can anyone show me in what order the oil pressure relief valve fits in an intermediate serpentine front cover please. I cant seem to find any info anywhere and I don't want to guess ! Appreciate any help thanks
Ray.
Serpentine relief valve
paul c
- Getting There
Re: Serpentine relief valve
From memory, piston, spring then spring cup and retainer clip.
Thanks Paul
Much Appreciated !
Ray
Much Appreciated !
Ray
[/img]
edit# from the manual to add:
Oil pressure relief valve - inspection
1. Clean relief valve components and piston bore
in timing cover.
2. Check piston and bore for scoring and that
piston slides freely in bore with no perceptible
side movement.
3. Check relief valve spring for damage and
distortion; check spring free length:
Spring free length = 60.0 mm
Oil pressure relief valve - refit
1. Lubricate new ’O’ ring with engine oil and fit to
relief valve plug.
2. Lubricate relief valve spring, piston and piston
bore with engine oil.
3. Assemble piston to relief valve spring, insert
piston and spring into piston bore.
4. Fit relief valve plug, depress plug and fit circlip.
5. Ensure circlip is fully seated in groove.
in timing cover.
side movement.
relief valve plug.
