Bellhousing for Mazda mx5 box to Rover V8
Does anyone know of a supplier of one to fit a 5 speed manual MX5 gearbox to a Rover?
Re: Bellhousing for Mazda mx5 box to Rover V8
Isn't the bell housing on the Mazda box integral with the main casing?
From the ones I've seen I'd say you are correct, integral bell-housing. May be possible to create an adaptor though. Wouldn't be cheap I'd imagine.
If you could get hole pattern data for the engine's rear end and the bell-housing it would be a starting point.
Other way would be to hack off the Mazda's BH and graft on a Rover BH.
Rpi do a kit with what looks like a bolt on bellhousing so I just assumed they were separate (maybe they modify the front of the box?) However, they wouldn't just sell one on its own. On reflection I think the cost is going to put a stop to this idea.
Just had a look at the RPi offering. Looks like they sell it as a conversion (at £4.6k) which seems to be specific to the MGB. May not be too bad if you have a top spec' MGB worth plenty of money but it's a fair chunk of change otherwise. From the photo's it looks like the front casing of the 'box is machined to suit the RV8 bell housing. I wonder it this is the MK 1,2,3 or 4 'box.
Not sure how good the Mazda 5 speed is, I've had two MX-5s, both with 6 speed boxes and I don't think they're as slick as many people make out although I have heard the 5 speed is a better change.
I'd also question the strength of a 'box from a car with, maybe, 160BhP and limited torque to go behind a RV8 with, hopefully, a good dollop more power and torque.
Why the Mazda box ?
Doesn't seem like an ideal or common swap ?
Surely a BMW box would be more common ? Or Toyota, or something
I think Jim at www.jrv8.co.uk was doing some Getrag conversion stuff a while back.
No idea who he is, or what box, it just popped up in a search
https://www.facebook.com/photo/?fbid=21 ... 1029935699
Another search
https://www.mdengineering.co.uk/lr-v8-adaptions/
RPI
https://www.youtube.com/watch?v=HbVHST5qZ1I
Another search
RPI
http://forum.britishv8.org/read.php?6,65883
not cheap at all
https://shop.v8engines.com/manual-gearb ... s-14-c.asp
not cheap at all
The RPi kit is not cheap but does include all the parts necessary including clutch, throw-out bearing and one or two other bits and pieces for the MGB, it's also a brand new box (apparently). Having said that I've had one or two sub optimal dealings with RPI in the past and I find their videos make me nauseous so I don't have any dealings with them these days.stevieturbo wrote: ↑Mon Aug 07, 2023 5:34 pm http://forum.britishv8.org/read.php?6,65883
not cheap at all
The Mazda 5-speed box is light and apparently strong enough for a 3.5 Rover but the bellhousing problem makes it a non starter now. The BMW box looks big and heavy, don't know about the Toyota box but both need a bellhousing at significant cost (ie too expensive)stevieturbo wrote: ↑Mon Aug 07, 2023 5:33 pm Why the Mazda box ?
What are you trying to achieve ?
What is wrong with a regular LT box etc ? or other more common options ?
LT77s are very thin on the ground these days and what are around probably need rebuild and I don't think parts are plentiful.stevieturbo wrote: ↑Fri Aug 11, 2023 1:29 pm What are you trying to achieve ?
R380s are newer and (apparently) inherently stronger but not many 2WD versions around as not too many RWD cars created in those days.
Reminds me, I have an LT in my garage which I swapped out for my R380, need to get that up for sale along with several other parts still in my garage.
T5 seems to be the most obvious choice and there must be bell housings around to fit them as some cars used them with RV8s, TVR for instance.
Probably not cheap though.
I'd have thought the easiest way to adapt any 'box to the RV* would be to cut off the front end of the Rover bell housing and the front of the donor bell housing and splice together. Notice I said "easiest" not "easy"!
If I were doing that I'd choose one with a detachable bell-housing though I think.
That approach is fairly commonplace, although usually beyond most DIYers. But certainly is doable.GDCobra wrote: ↑Fri Aug 11, 2023 4:57 pm
If you have a lathe, mill etc and can weld....all the easier. Without any of these....not so easy.
Reality.....just accept the kits cost money and stump up.
This doesn't mention what engine, or whether vat is included
https://www.moss-europe.co.uk/five-spee ... 30721.html
No idea why this comes up in Italian ? lol. Brand new box
https://www.mx5parts.co.uk/speed-gearbo ... -1263.html?
Moss must be incl vat ? This is less VAT
https://www.vitesse-ltd.com/products/mg ... 1996386387
Many many years ago I got a RV8 to R154 kit from NZ
http://www.conversioncomp.co.nz/index.php
Exchange rate was better then, and boxes were readily available. Not so much either now. Any conversion you choose, should be a box that is readily available, just to ensure an ability to service it in the future if needed.
Considering the nature of the new bellhousing required on the MX5 kits....the prices don't seem unreasonable as it forms a chunk of the gearbox itself. That's a large new casting with a lot of machining
https://www.youtube.com/watch?v=F8uFZq7KhdE
New bellhousing for a Tremec, and new boxes are available....at a price of course.
https://roadcraftuk.co.uk/index.php?rou ... uct_id=544
https://roadcraftuk.co.uk/index.php?rou ... ath=45_141
Still in the £2-2500 range and a bit, although a few more options and separate parts.
Bellhousing flange you might be able to adapt and weld onto an old MX5 box yourself ?
One route to a Nissan CD009 swap, again, their approach might allow you to adapt an existing bellhousing to their adapter. But as these boxes can be popular with drifters, may be more pricey
https://www.youtube.com/watch?v=Z6ETCVJN2mU
The "RPI" kit is just the Vitesse kit: https://www.vitesse-ltd.com/products/mg ... 2018439251GDCobra wrote: ↑Mon Aug 07, 2023 12:23 pm Just had a look at the RPi offering. Looks like they sell it as a conversion (at £4.6k) which seems to be specific to the MGB. May not be too bad if you have a top spec' MGB worth plenty of money but it's a fair chunk of change otherwise. From the photo's it looks like the front casing of the 'box is machined to suit the RV8 bell housing. I wonder it this is the MK 1,2,3 or 4 'box.
