TVR 350i Rebuild
Alan T
TVR 350i Rebuild
Post by Alan T »
Hello everyone
I'm currently rebuilding my 350i Wedge engine and have got to the point where I need to start thinking about camshafts, so far I've had the following done:-
Heads skimmed and cleaned
Block faced and cleaned
Crank reground
Flywheel faced and lightened slightly
I also be using an Edlbrock 500 with Offenhauser manifold.
As the car is predominantly for road use I can't decide which cam to go for and which ones are designed for a carb as opposed opposed to the original flapper injection, my current thinking is to go for a high torque one to give lots of low down power rather than making it too peaky.
Any advice on this would be appreciated.
Re: TVR 350i Rebuild
Surely on a TVR, you don't want a stump puller cam?
Rover V8's aren't lacking in low down torque - they are lacking in higher RPM power - I would personally choose a cam to wake it up higher up the rev range like 2000-6000 range.
I used the standard 3.9 cam in my SD1 EFI. Although the MegaSquirt helped the bottom end a great deal over the flapper injection. But it still does that 'lift up the skirts' feeling above about 3500 rpm.
Alan T
Post by Alan T »
Thanks for the replies chaps and point taken, the reasoning behind me thinking about a 'stump Puller' cam was because these engines struggle to make power at the top end without an awful amount of head work to enable a high bhp cam to work properly, but I'm open to all suggestions. So if I go for a "fast road" type cam, which ones will work with my choice of carb and without having to pocket the pistons. Thanks again :D
