Engine build
Ralphypants
Engine build
Hello all.
I have a 4l rv8 in my Dax Cobra producing 182bhp and I’m thinking that I would like a little more power. My cam is an rc87 I think. I have heared I will need to move up to 4.6l. I don’t have masses of cash, sadly. Who would you recommend to build me a lively, reliable engine. I’m not looking for gas guzzling mega performance 500bhp, around 300bhp would be fine.
Your thoughts please.
Colin.
Colin.
Re: Engine build
300BHP is going to be fairly expensive on that engine.
I have aimed for 300BHP with my latest build, although I have yet to get to a rolling road to see how close I am. Key points are:
- 4.6l bottom end (with top hat liners)
- Warrior heads (Stage 3) from V8 Developments.
- Stealth camshaft from V8 Developments.
- Bosch Motronic 'Thor' fuel injection (i.e. the one found in a late Range Rover P38)
So you can see there's a few grands worth. You could save a couple of grand by just getting a 2nd hand bottom end and not rebuilding it / relinering it.
I can report that performance is very lively with that configuration.
Re: Engine build
Isn't the Thor top end better for low end torque rather than peak power, over the earlier plenum? So more suited to a 4x4 than sports car?
- Rossco
- Moderator Gold
Re: Engine build
Ralphypants unfortunately there is no such thing as a 'cheap' 300bhp Rover engine.
Looking at ChrisJC's suggestion, which is perfectly reasonable, my first thought is that's going to start at £5k whoever you get it from.
Adjusting expectations might help you out. If you were happy with 250bhp then a 4.6 with decent cam and some DIY work on the inlet and heads would get you there.
Ralphypants
Re: Engine build
Yes , a ball park of 250 bhp is fine. I’ve heard good reports of Ray Webb at V8 developments, can anyone confirm this?
Colin.
Colin.
Re: Engine build
I got some of my stuff from Ray. No problems that I can recall. Everything OK so far...
Re: Engine build
That is reputedly true. I stuck with it as I fancied the Motronic EMS as I've got it in my P38 and it seems very good.DaveEFI wrote: Tue Jul 14, 2020 10:01 am Isn't the Thor top end better for low end torque rather than peak power, over the earlier plenum? So more suited to a 4x4 than sports car?
We'll see how it looks on a rolling road!
Re: Engine build
Yes- the Motronic is very good. But can you get rid of the cats?ChrisJC wrote: Tue Jul 14, 2020 3:38 pmThat is reputedly true. I stuck with it as I fancied the Motronic EMS as I've got it in my P38 and it seems very good.DaveEFI wrote: Tue Jul 14, 2020 10:01 am Isn't the Thor top end better for low end torque rather than peak power, over the earlier plenum? So more suited to a 4x4 than sports car?
Re: Engine build
Don't know - I kept the cats!DaveEFI wrote: Tue Jul 14, 2020 6:12 pm Yes- the Motronic is very good. But can you get rid of the cats?
