which heads
MARSHY
which heads
Post by MARSHY »
Hi , i am rebuilding a 3.9 engine with a mild cam upgrade and was thinking which heads would give me some slight performance improvements,I have some slightly ported 3.5 heads some 4.6 standard heads and some standard 3.9 heads .Which do you think I should fit , regards David.
kokkolanpoika
Re: which heads
Post by kokkolanpoika »
Go for 4.6 heads. Exhaust port is bigger near valve guide vs old style heads.. Also you get more compression ratio.. You can also port those 4.6 heads.
Timo
garrycol
Re: which heads
Post by garrycol »
kokkolanpoika wrote: Wed Jul 15, 2020 6:39 pm Go for 4.6 heads. Exhaust port is bigger near valve guide vs old style heads.. Also you get more compression ratio.. You can also port those 4.6 heads.
With standard heads, compression ratio comes from the pistons used, not what heads are used.
Re: which heads
Heads designed for a steel gasket are higher than those for composite. If you use heads for steel with composite, you'll end up with a lower CR than the pistons say.
Re: which heads
To clarify here, there are two thicknesses of head gasket. Thin 'tin' ones and thick 'composite' ones. The heads are machined to suit a particular gasket type, so a head for a tin gasket is about 1mm taller than for a composite gasket. The idea is that overall, the combustion chamber volume is the same, and the compression is set by the piston.
You can mix & match gaskets and heads, but it does mean that the hydraulic tappet preload will be incorrect (as it depends on the distance between the camshaft and the rocker shaft), so you have to compensate for it by shimming the rocker shaft pedestals!
Best bet is to keep head & gasket type matched, and choose pistons to suit your end-goal.
Mc Tool
Re: which heads
Post by Mc Tool »
And use waisted stem valves :D
