Range Rover 17D - detuned?
How do! I have just aquired a RR 17D ( yes has the manifold air injection ) from a very nice couple on the Wirral ( hiya Gary - if you are a visitor/member ). Anyway the lump checks out pretty well ( although i'm planning a strip down anyway ). The question is - i remember the RR v8's being lower powered - 140 bhp ish i think. How was this lower state of tune 'achieved' ? Was it carbs,exhaust, cam or all three? The 'Pulsair' is not an issue as i have some SD1 cast manifolds in my 'parts dept'
I've decided on installing the RRv8 instead of the p5b engine for ease of use and parts but i will also rebuild the p5b lump. I fancy something out of the 'norm' for carbs - has anyone got any thoughts or what has been used before? ... John
Re: Range Rover 17D - detuned?
There is a fourth factor!, compression ratio. This is set by the pistons, but should be stamped on the block above the engine number.
Hi Chris - I'd already checked the compression ratio and it's 9.35 : 1. Is it likely that carb jetting or reduced choke diameter was the way that they were detuned .... i wonder..
I think that is about the max for a carb Rangie engine. The EFi version of the same was 165BHP.
One has to assume it's a combination of cam, exhaust, ignition timing.
The EFi version had twin outlet manifolds which must have helped over the single outlet manifolds used on the carb engines.
