ford cosworth T5 - 5th gear problem
- Seight-V8
- Knows His Stuff
Hello all,
Anyone had a problem with a Cosworth T5 gearbox, where it wont engage 5th gear?.....
All the others are selectable, but 5th seems to only slightly engage and wont go fully into gear.
Baring in mind its a new rebuild from a T5 gearbox company, and has not been driven yet.
Maybe the gearbox oil hasn't circulated enough yet, as the whole gearbox feels notchy when selecting gear, once the engine is running it might feel better?
cheers
scott
cheers
scott
Re: ford cosworth T5 - 5th gear problem
The 5th Gear has a separate selector rail (which also selects reverse). This rail slides back and forth in pockets in the front and rear of the gearbox casing and any burrs on the rail can make the movement stiff. Once the oil gets about it should improve if that is the problem. Or it may be that the 5th syncro ring is sticking due to long storage and isn't lining up so try moving the prop a few turns backwards and forwards.
- Seight-V8
- Knows His Stuff
thanks, I've been out around the block for a short drive today.
I've used 1st to 3rd gear anyway and reverse.
5th does now seem to engage further, but i cant actually tell till i can get enough speed up on the road.
Maybe like you said just needs running in, after 3 years dry and after recond.
regards
scott
regards
scott
- richardpope50
- Gold Member
Don't suppose a piece of plastic has fallen off in the selector / gear lever box? Just removethe plate and have a look to check.
Richard.
The top plate cannot be removed until the rear housing is removed which would mean gearbox removal from the car. Also the plastic bits on the selectors are not involved in the 5th gear selector rod shifting/movement.
- richardpope50
- Gold Member
To clarify as this actually happend to me. Remove the gear lever by removing the four bolts and its holding plate. Remove gear lever and the nylon sphere thingy has an offset hole in it. Turn it 180 degrees and replace. You will now get 5th and reverse as the offset hole will allow the gear lever to move across to select them.
An easy mistake when putting the gearlever back.
Richard.
Sorry, I misunderstood, I thought you were referring to the plastic selector bits that are inside the actual gearbox on the selector forks.
- richardpope50
- Gold Member
My mistake in explanation.
I definately had this problem and was simple to fix. I think it was an offset hole in the nylon sphere or something else I put in wrong.
Richard.
Hopefully we will find out if this was the problem.
