The build begins... 1932 Ford 4.6 Rv8
Hot rod Ed 32
Just a quick ask! Do you think an inlet with su carbs will be ok on 4.6 Rv8
Re: The build begins... 1932 Ford 4.6 Rv8
I know people that have done that and not had any problems. It won't give the ultimate in performance but if you're not looking for that it will be fine. Just use an HIF manifold and carbs.
I found that 1.75" SU's were a bit small at full chat. I switched to 2" SU's and ported the manifold.
im now running a 4.6 on 2" su`s got mine from a jag not set up as yet but a lot better
