Rover v8 misfire/tacho flicker
Afternoon all, took my Dax rush out yesterday for the first time since engine removal and install, first half hour was perfect however after that I seemed to develop a misfire on all cylinders while at the same time it would loose power to the tacho, it did this a few times then would run perfectly for a couple of mins then back to this so I'm guessing it's a loose connection somewhere, it's running a carb so can't be a lot. Whatever it is it's where tacho and ignition are linked as both went at the same second. Any ideas where to look first or any tests that can be done to rule out various components.
Thanks Sam
Thanks Sam
Re: Rover v8 misfire/tacho flicker
If you have the DLM dizzy with the amp on the side, the amp is the first suspect. When I had that dizzy, used to carry a spare amp.
Points dizzy?? check gap of the breaker points.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Building a GT40 mk2
Either the supply to Coil positive, or the link between Coil Positive and the amplifier, or the amplifier itself.
I would get a 12V bulb and a couple of long wires. I'd connect one side to Coil Positive and the other to earth and place the bulb inside the car.
The bulb should remain on all the time the engine is running. If it goes out or flickers, you've got a supply problem.
If it does remain on, and the wiring looks OK between Coil Negative and Amplifier, then change the amplifier.
Thanks for replies, it's running a msd blaster 2 coil and msd digital ignition so not sure if it has an amplifier? The distributor has the hall sensor type sensor in it. The bulb idea will still work though I'm guessing.
Thanks again
Thanks again
Dunno MSD. Is there fault finding guide for it?
Couldn't get my MSD6AL working properly on a Lucas Hall type distributor ending up with the early points type dizzy for a while. Finaly I bought the MSD Pro Billet dizzy which runs perfect for years now.
Building a GT40 mk2
Building a GT40 mk2
Don't think any Lucas dizzy had a hall sensor. Tbe DLM has a VR sensor.
All sorted turned out Msd coil was not playing game.
Thanks for inputs
Sam
Thanks for inputs
Sam
Back when my engine had a dizzy, I had numerous problems with coils and ignition amps. It was all caused by the regulator on the alternator being shot and putting out up to 17v. Give it a quick check.
Mc Tool
- Helpful or Confused
Just to put another possible fault for those chasing cures , I have a 1980 Capri which would take a dump from time to time and the tachometer would go at same time , sometimes of such short duration that the tach needle barely had time to drop right down to zero. Then it started dying for 10 mins at a time ......turned out to be a short in the tachometer .which Perminantly. earthed the coil via the tach signal wire.....if left to cool down it would go again ....maybe 15 mins to cool. Held up peak traffic on Nelson's Bishopdale hill for ages
