Uncobra, the V8 FrankenHealey
kev_the_mole
Ian,
I have a full track day booked at evil Keevil on 6th August for setup and tracking, tyre pressures etc.
I also hope to have a GTech performance measuring jobby for provisional performance figures and when that's all over a general hooning session.
Then as soon as possible off to a rolling road to see if my 325 USA horsepower are 'my little ponies'.
Then it's fuel injection over the winter as the next project
Your namesake
Your namesake
It's an engine Jim.....but not as we know it
kev_the_mole
kev_the_mole
kev_the_mole
The zorst boys did a very professional job. There's about 5mm of clearance round the 'box and the end pipe is stainless.
....the pipes look a lot better from above rather than at ground level
They're supposed to be 100dBA max but we'll have to see at the track
kev_the_mole
kev_the_mole
Mike,
they're Fleabay Compomotive ML's. Got six for £300 so I've got two sat in the garage with 'drag' tyres on waiting for that wonderful newbie day at the 'Pod or elsewhere. I've always like the Minilite style wheels and had them on my old Healey. If you're looking around beware that there are some dodgy replicas / companies. There's a horror story on the old Forum if you look here http://www.v-8.org.uk/snitzforum/topic. ... s=minilite.
Hi Ian
I remember that thread, partly why I asked, your ones looked rather nice, better made than many. Its is getting around to the point where I have to start lookinf for wheels for the Mclaren, the only thing for certain is the BBS things I have now won't do! torque thrust II might (if I can get them in wide enough width for the rear and 17" or 18" diamiter) whay I would really like is a suitable sized version of the old Revolution 5 spoke
but able to take a modern wide tyre.
kev_the_mole
McClaren???? F1???
Now I get the significance of the 'Kiwicar' name.
Got a picture?
Let me know the PCD, diameters and widths you're looking for and I'll ask my friend who has a mezzanine full of old Lola and sports racer wheels. If he doesn't have anything he may know where something may be found.
Got a picture?
Not a picture of mine
http://www.mathewscollection.com/images ... _3_450.jpg
Mclaren M1C from a autotune kit, chassis stiffened and an Audi box (which I will blow to bits first time I hit max torque
Hence also it needs to be on FI stacks for the inlets!
The wheels are Jag PCD (4.75 inches in real money with with a 74.1 mm center bore) with jag front uprights and re-studded Granarda rear hubs, I may convert the whole lot to jag centerlocks (or any centerlocks) if the right wheels came up, I have 350 mm AP disce up front with XK8 315 front discs on the rear so i need atleast 17" fronts and 16" rears, oh and it has to be road leagle
I don't want alot really
kev_the_mole
Some of the trackday / shakedown day pictures are in. It was the best of times; the worst of times. I could drive it for the first time in sixteen months but not everything went right but I didn't stuff it
Got to Keevil, had the newbie briefing, went out on the acclimatisation laps and then the open pit lane started. The car went very well but we had a water dump problem after every run
and we hadn't taken any water! However the most enterprising team member begged a can full of the old cooling fluid from the event organisers
Where's the leak???
then a few drops of oil appeared at the front and the back so out came the jack
It looked like the timing cover seal had given up and that we were losing
copious amounts of oil from the back axle.
and eventually the vibration caused one of the bonnet locks so get out of sequence so we couldn't get the the bonnet open - end of play
H O W E V E R
the good parts were awesome
She goes like a scalded cat in a straight line
Got the popular vote as the best sounding car of the day
Out-accelerated a Porsche 997 GT3 RS (he may have been in the wrong gear but I don't care
Goes round corners better than I thought for a 1954 car with a huge weight in the front
and the brakes, while needing upgrading, still hauled her down to a reasonable cornering speed from 110mph without fading too much
These are off the event photographer's website hence the watermarks
WATERMARKS NOW REMOVED
this is the view most of the other drivers saw of us on the straights
them Caterhams are buggers in the twisty bits though and then I spun out through a combination of over-enthusiasm, too much steering input and rear wheel steer and, of course, a lack of talent.
Go away you nimble git
So now it's back to sorting oil leaks, putting in an expansion tank to stop the overflow, fix the bonnet catches, get an MOT etc etc etc
Where's the leak???
H O W E V E R
Congratulations Ian
She looks great and all cars have a few niggles when irst out the box.
Hopefully repairs will be done soon than time for mor play!
[/img]
