well not the sort of week I wanted while off with clutch issues to sort out,
but finally this happened on Easter Monday,
After a 2yr project with
www.v8performanceparts.co.uk the new 4.8ltr RV8 is fitted into the Capris engine bay,
Spec is:
Standard bore x-bolted 4.6 block with top hat liners.
4.6 crank offset ground for 3.4" stroke.
Diamond forged pistons
Total seal rings
Lunati H-Beam SBC rods narrowed to fit and rebushed to 0.866"
Crower 50305 cam
Crower solid chevy lifters
TA heads
TA Roller Rockers
45mm trumpet base
Rotrex supercharger.
Fuelling and ignition are done by Megasquirt.
- 1.jpg (93.06 KiB) Viewed 6984 times
- 2.jpg (96.75 KiB) Viewed 6984 times
- 3.jpg (100.47 KiB) Viewed 6984 times
- 4.jpg (73.52 KiB) Viewed 6984 times
- 5.jpg (75.89 KiB) Viewed 6984 times
- 6.jpg (74.57 KiB) Viewed 6984 times
- 7.jpg (96.07 KiB) Viewed 6984 times
