Servo vacuumed INFO
Servo vacuumed INFO
Does anybody no how much vacuumed is produced by the V8
I think I need to fit a 12volt vacuume pump to improve the brake servo/master cars braking
Thanks for any advise
fordpop52@aol.com
fordpop52@aol.com
Re: Servo vacuumed INFO
That very much depends on the engine.redm6gtr wrote:Does anybody no how much vacuumed is produced by the V8
fordpop52@aol.com
But I can see very few applications needing an electric pump.
If you are having problems you then need to look at the plumbing to the booster (do you have it off the right takeoff - the pipe/outlet is about 10mm in size) or you have a booster problem.
If the problem persists you could always put in an alternator from a TDI or TD5 which has a inbuilt vacuum pump.
But there is no issues in an RV8 providing enough vacuum
Garry
Garry
A Rover V8 in good condition (like pretty much all petrol engines) will pull an almost total vacuum under overrun conditions.redm6gtr wrote:Does anybody no how much vacuumed is produced by the V8
fordpop52@aol.com
Rover V8 brake issue
Guys
The rover is fitted with a fast road cam the inlet is an Offernhouser fitted with a pair 45 Weber carbs also a Mallory dist
The brakes were a 7 inch servo with a mark 2 jaguar master
They both needed replacing so I fitted a new servo with a 1 inch bore master
A mistake it should have been a 7/8 bore
There is a one way in the servo pipe
So now I have another master on order and will fit a 12 volt power servo pump from a BMW/VW for extra vacuum
So we will see how it goes
I'd have thought you'd notice that by poor engine performance before the brakes?mike-b wrote:Others reading this may well know better but to raise a point - Would a leaking inlet manifold not play a part of the problem, or even be it?
Possibly...but I dont think there has been a proper explanation of what is even wrong with the brakes ?DaveEFI wrote:I'd have thought you'd notice that by poor engine performance before the brakes?mike-b wrote:Others reading this may well know better but to raise a point - Would a leaking inlet manifold not play a part of the problem, or even be it?
Yes - is the booster connected to a small bleed port in the manifold or a proper large bore bore specifically the size for a booster? Also the brakes seem to be a mish mash of components that may not be compatible with each other.
I doubt a vaccum pump will fix the issue if the same size plumbing as is in place now is used.
The RV8 develops plenty of vacuum - as evidenced by the hundreds of thousands of setups around the world that are working fine - so there is something wrong with the OPs set up not the vacuum.
garry
garry
