Frankencarlton
Not to derail...but some threads in the US with pics of various setups
http://www.yellowbullet.com/forum/showt ... hp?t=51574
http://ls1tech.com/forums/forced-induct ... lease.html
JJMclure
Post by JJMclure »
Its a 60mm gate
Thanks for the links!
don't nibble on the barrel, pull the trigger!
There are loads more, although those are more focused on photos just.
Some pretty amazing builds all over the place !
https://www.youtube.com/watch?v=A7EnVHudTE0
JJMclure
Post by JJMclure »
Nice! Although when he says budget its probably way out of my budget!!!
Makes good numbers for the psi, i wonder what poundage the injectors were, cam specs etc etc
It wouldnt be overly hard with most cams, and there are literally dozens you could choose from.
All the cams I've used over the years have been very mild, although changing for a slightly bigger one this year. But again, still nothing wild. I like a smooth idle !!
They're probably on 1000cc injectors or thereabouts, although at a push they could probably do it safely on 800cc or so.
