Frankencarlton
Its probably a bit tricky to see from the pics both banks feed into the offside the wastegate is on the nearside single vband. Im happy with the exhaust as its not a 2000hp full on rip yer ead off race build, i will be happy as long as it makes 500 which will be more than enough to start with. I want to try and get the car about 1200kg and not push the engine too hard as i want to try and keep "some" reliability hahahahastevieturbo wrote:Lots of nice work going on, although flow path to the wastegates is a little odd.
How come you didnt keep all the hot pipes low and come into the turbo from underneath ?
don't nibble on the barrel, pull the trigger!
I can see the routing ok....just that the flow path isnt smooth to the gates, as both almost need to make a u-turn prior to the turbo flange.JJMclure wrote:Its probably a bit tricky to see from the pics both banks feed into the offside the wastegate is on the nearside single vband. Im happy with the exhaust as its not a 2000hp full on rip yer ead off race build, i will be happy as long as it makes 500 which will be more than enough to start with. I want to try and get the car about 1200kg and not push the engine too hard as i want to try and keep "some" reliability hahahahastevieturbo wrote:Lots of nice work going on, although flow path to the wastegates is a little odd.
And Eliot makes a good point, that's a lot of pipework there with no ability to move, expand or contract.
It's all about flow.
You'll see people talk about creating flow priority for the gate or gates. It's basically just ensuring a free and smooth flow path to the gate.
With your current setup....the flow will not be smooth. A simple modification where it does that U type 180 turn to get to the gate would make a big difference to flow
That said, the only negative effect it will have if flow is not sufficient, is too much boost. Usually in the form of boost creep as rpm's rise and/or a higher low boost target than you had hoped for.. But the pipework looks to be a fairly large diameter, so because of that, it may well be fine.
By that I mean the pipe to the gate looks to be same size as the pipe feeding the turbo, not smaller. So it should be able to leak off a considerable amount of air despite the flow path.
TBH I'd have just thrown a pair of gates onto it, one gate on each pipe prior to the turbo. There's no lack of pipe to install them onto it, and that way would also simplify plumbing.
What size is the gate you are using ?
[/URL][/img]
[/URL][/img]
