Firstly how many wires come off the dizzy body? If it's just one then there's no need for an amp. Just connect it (black wire I think?) to the -ve side of the coil.
If there's 2:
Is the amp attached to the dizzy body or does it sit behind the coil?
Normally (a word to be taken with a pinch of salt when refering to RV8 electrics!) there's 2 wires coming from the dizzy to the ign amp (if separate from the dizzy body). These are both white and I don't
think it matters which way around they're connected to the amplifier as it's just a magnetic inductance sensing circuit.
Plus 2 wires coming from the amp to connect to the coil. One connects to the low-tension (e.g the spade connectors) coil -ve and the other connects to the coil +ve.
OR
There's 2 wires coming from an amplifier mounted to the dizzy body. One is coil -ve and the other coil +ve.
I'm not sure about wire colours going from amp to coil, sorry.
P.S to I.D your dizzy - look here:
http://www.v8engines.com/electrics-1.ht ... electronic
Any problems ring them up and ask to speak to Ian - pretty much anything electrical with the RV8 he knows, at least that's my experience!
