Push rod mechanical lifters??
kokkolanpoika
Post by kokkolanpoika »
Hi..
Need some information..
I have got rover v8 and i bought Kent M228 mechanical cam + followers.
And i now need adjustable pushrods or adjustable rockers? or both?
I´m thinking if i can use std rover pushrods, mechanical followers and i only buy Yella Terra roller rocker arms? Is this possible?? Or do i need also some special mechanical followers pushrod??
Also i look Land Rover discovery TDI 300 rocker arms, they are steel + also adjustable, but i dont gnow will they fit V8 rocker shaft? And what rocker ratio they have got? Also need special push rods??
Or any better ideas??
Timo
Post by ian.stewart »
you will need one or the other for a mechanical cam, Im not sure about the yella terras, I think you may need to use small block ford pushrods,
Steel adjustable rocker arms normally used ar Volvo ones from the pushrod engine, 122 I think, They were used by Tom Wilkenshaw in the ETC championship untill they were discovered by the scrutineers as a Non Homologated part, especilally as they still had Volvo cast into them.
Never heard of oilway restrictors in the lifter valley on a rover, but it may be an idea to give better mains pressure when using solid lifters,
Ian :D
THE SMOKING GNU
