MX5 V8
MX5 V8
Hey,
I bought Andy's old MX5 V8 last October and after a couple of running issues Andy told me about this forum.
The car is a mk1 MX5 which a JRV8 3.5 Rover engine. Just had it on the rolling road today and it made a measly 164bhp. Every fuelling/ignition reading was perfect, any suggestions will be really welcome!
MX5 4.6 V8
Previous of many SD1's back in the day!
Re: MX5 V8
What is the spec of the engine? 164 bhp is more than many, but less than some.southernd wrote:Hey,
Note that RV8 cams - especially 'wild' ones - can have a pretty short life. And the engine can appear to run ok, but be well down on maximum power.
Hey Dave,
It was option 3:
http://www.jrv8.co.uk/engines/
285 cams if I remember and a pretty extensive rebuild. Built for around the 200bhp mark. It's done very few miles since rebuild, less than 10k from what I can see. I've yet to do a compression check but there's zero that sticks out as an issue. Torque wasn't that high either.
It was option 3:
MX5 4.6 V8
Does it really feel short of power on such a light vehicle? I know we all want more.southernd wrote:Most likely I'll try and get hold of an experienced Rover V8 mechanic. If the engine proves no good I'll look at getting a 4.6 short block, a bit of work but more powerful from the start
If the heads are stock and unmodified you can put as much cam, carb and compression as you like on it - It will not do 200BHP - for stock heads 168BHP is about as much as you could ever expect.
ETA
Graph shows as expected with stock deads - flow stops after 5500. Lift the valve as much as you like and put as much carb behind it as you please - the air will not get past the restriction in the throat.
Spend £4-500 having the throats opened up and some decent seat cut and it should see 225BHP.
ETA +
The torque increase from 2500 would be what you would notice most with the head works.
Andrew
ETA
ETA +
Andrew
4.5L V8 Ginetta G27
They didn't tell me much to be honest, I got the print out you see
If anyone remembers the MG Maestro, it feels like that. Yes it's nippy, it will move if you spank it but nothing like a V8 should. I'm not a BHP snob, it's not something I normally chase but for a V8 it just doesn't have much umph.
They are Vitesse cylinder heads, I'll Google them in a mo. Looking at the invoice/list of work the compression was raised to 9.75:1 and a hurricane camshaft, the rest was pretty much a full rebuild.
MX5 4.6 V8
