As to be expected I see there is a lot of Rover V8 activity in this section (which I've had my share of...) so how about something different?
I present here a summary of my EFI conversion of the Chrysler 440 cubic inch (7.2L) engine in my '74 Jensen Interceptor. Pics below.
Summary of the conversion:
1) Edelbrock PRM intake manifold modified to accept injectors;
2) Edelbrock EFI throttle body with TPS and PWM idle valve;
3) Discovery 2 V8 EFI submerged EFI pump;
4) Jaguar XJS surge tank with EFI pump inside;
5) Dual EDIS-8 coil packs with HT wires made by Magnecor;
6) Ignition module consisting of 4 BIP373 transistors, controlled by Megasquirt;
7) EFI control (fuel and spark) by Megasquirt-2 on a V3 board;
I have a downloadable PDF file of the project here: https://dl.dropboxusercontent.com/u/152 ... 202013.pdf
A very comprehensive thread on this conversion can be found here (I suspect you may have to register to view it): http://www.joc.org.uk/phpBB2/viewtopic. ... 540ed030e2
This is what it looks like after the conversion:
