flywheel bolts
flywheel bolts
I got a set of ARP flywheel bolts for my Rover V8, which are really Chevy ones but the same size, the instructions say 85lbs torque, Loctite 242 on threads, ARP lube under heads, as the RV8 flywheel torque is 60 lbs is this 85 lbs just for the Chevy ?
From my own experience I would use the Rover torque setting Denis as these bolts wont stretch when in place. ? There are no special instructions from Real Steel when using these bolts for the Rover ?
Pel
Pel
