Rover V8 3.5 ignition problem
ratrod504
Post by ratrod504 »
PostPosted: Mon Oct 05, 2015 1:22 pm Post subject: Rover V8 3.5 running problems Reply with quote Edit/Delete this post Delete this post
Hi members... i have recently fitted a Rover 3.5 V8 into a car i have built.
The engine came from a Landrover and got SU carbs with the bowls underneath the carbs, never seen these before.
The problem i have is that engine starts first time everytime, runs for 10 seconds or so then stops. Seems to flood up. I have noticed the coil gets warm after several attempts of starting.
Anyone had these sort of symptoms before?
I have no choke on it and fuel is pumping up to carbs by electric pump.
I have tried different coils and the little white box near coil, and new leads.
Any help would be appreciated
Thank you
ratrod504
DEVONMAN
Post by DEVONMAN »
Once you have it running, disconnect the fuel pump and see if it runs for a little longer than 10 seconds. If it does then also try putting the pump on and off every 5 seconds and see what happens.
It may be that the a float is stuck down in one of the carbs and gradually flooding it. Try a few taps on the side of the bowls with a wooden hammer.
Or it may just be some crud in the float chamber needle valve.
Denis
