5/16" ball end for pushrods
Any one know if you can get a 5/16" ball end for the adjustable end for the adjustable pushrods?
SimpleSimon
Post by SimpleSimon »
Tony give Real Steel a tinkle 8-) am sure you have already 8)
sidecar
Post by sidecar »
You can for the non-adjustable end, I'm not sure if you can get two sizes for the adjustable end though!
SimpleSimon
sidecar wrote:You can for the non-adjustable end, I'm not sure if you can get two sizes for the adjustable end though!
My bad :? I see what Tony is saying, I guess you could always run them upside down with the 5/16 ends facing up and the 3/8 facing the lifters if your using hyd RV8 lifters but it will be a pain having to set the pre-loads with the intake removed :(
dnb
Post by dnb »
Sounds like an excuse for roller rockers to me... ;)
:wink:
