G17A
aspira
G17A
Post by aspira »
Hey Guys - I've got a G17A 287 40 B gearbox.
It came from a 2300/2600 SD1. I know it's not perfect but will this box be okay for my MGB V8 Project. Using a 3.5 SD1?
Many thx
1978 MGB Roadster
Rover 3.5 V8, Edelbroke Carb, MX5 gearbox
Darkspeed
Post by Darkspeed »
Perfectly adequate - you should have no worries about using it.
4.5L V8 Ginetta G27
aspira
Post by aspira »
Great, thx for the response. Just need to make sure it's a decent box now. Hard to really tell I guess when it's on the workbench.
1978 MGB Roadster
v8250
Post by v8250 »
Aspira, if you have no idea as to the condition of the gearbox, get it rebuilt. Unless you're doing some mounting trickery it's engine and gearbox out together with the MGB which is a right royal pain. Better to know you've got a good correctly built gearbox from day one. TM Transmissions are competitive for an exchange gearbox.
aspira
Post by aspira »
You're probably right, I don't want to pull the gearbox once its in. I've been trying to work out how you can test it but it seems impossible without stripping it down which isn't a job I fancy. Thx, I'll try TM Transmissions and see how much it might cost.
1978 MGB Roadster
v8250
Post by v8250 »
bodger
Re: G17A
Post by bodger »
aspira wrote:Hey Guys - I've got a G17A 287 40 B gearbox.
Many thx
i thought the 2300 box was a 4 speed version ??
Re: G17A
Many thx
IIRC, only early ones.
