Rover SD1 V8
Rover SD1 V8
Hi Guys, I am currently rebuilding a Rover V8 SD1 engine first time, my question is when I come to the timing cover and priming the pump.
I have read that you can fill the housing with petroleum jelly, any one have any pics of this, also does it interfere with the oil, sorry but I am a novice on this.
Any advice much appreciated
Andy
Andy
Rover!!
As Scudder says.... Definatley use a priming tool to get oil around the engine before first start after a rebuild. You can make one easily or buy one for a few quid. Its one of those tools that will pay for itself time and time again mate.
Perry
Perry
You don't want no grease or jelly in your oil.
That trick is an hit & miss anyway. It can get you taking of that oil pump for several times to repack with grease before it works.
Simple best method.
Overfill the engine with engine oil. It takes about 1½ litre extra. At this point oil level is just above the pump.
Leave the oil filter of the pump ( get a bucket or track under that ), prime the pump till oil flows out of the pump and done.
Drain the extra amount of oil till proper level.
Its just a matter of seconds.
Simple best method.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Building a GT40 mk2
