4.8 stroker kit
nickm
4.8 stroker kit
Post by nickm »
Does anyone know if the 4.8 stroker kit is still available for the 2 bolt main/small diameter bearing Rover V8?
Does anyone have any experience of the conversion?
Nick
Cobratone
Is a Spanner
Post by Cobratone »
I did that same conversion some years ago. I struggled to find a supplier and eventually John Eales made me one up, wasn't too bad price-wise too, compared to the price of realsteels kit
nickm
Post by nickm »
I might give him a try.Was it a worthwhile exercise?
Cobratone
Is a Spanner
Post by Cobratone »
In a word, Yes. With the throttle bodies and a very mild cam The engine made 307 Hp at one of Pels RR days :-)
nickm
Post by nickm »
That's pretty impressive.I spent a load on tuning a 4.6 and it still only made 260bhp.
Cobratone
Is a Spanner
Post by Cobratone »
nickm wrote:That's pretty impressive.I spent a load on tuning a 4.6 and it still only made 260bhp.
Sidecarbod on here has a 4.6 that is pushing 300 bhp or close to it, maybe he can give you some pointers??
sidecar
Post by sidecar »
My 4.6 does indeed make around 300 BHP, the last time that I had it on the rollers it was making around 285 but I've done a fair bit more to it since then, my seat of the pants dyno reckons that there is easily another 15 BHP so I'm calling it 300! :shock:
(It makes another 100 BHP when the NOS is running!!)
My lump runs 10:1 CR, V8 develpments stage III heads, a Piper 285 cam degreed in with vernier gears. I run adjustable pushrods and I have carefully set the preload to 20 thou on all valves. I run a port matched Edelbrock manifold and an Eddy 500 carb that has been carefully recalibrated using an LC1.
I got a BIG improvement in the top end BHP (above 5k) by running a programable MSD system, I removed all of the internals so that the dizzy is 'locked out', I made a new baseplate and fitted an MSD pickup that is triggered by the standard Lucas trigger wheel.
I also run 1+3/4" headers which are around 30 inches long which run into two sidepipes. (The car is a Cobra replica).
I think that it is quite possible to get more than 300 BHP from a 4.6 with a better induction system but the Eddy manifold is what I had when I built the engine!
nickm
Post by nickm »
My 4.6 was built by John Eales and had big valve heads,piper 270 cam and an edelbrock inlet manifold/500cfm carb.I had it in a Westfield and made it go like stink.
The idea behind the 4.8 is that it is going in a Land Rover 110 where torque will be be more important.
Nick
