p6 4 speed
v8saph
p6 4 speed
Post by v8saph »
just a quicky will a 4 speed p6 v8 box be ok for my sierra ie will the gear lever be roughly in line with same hole in the tunnel :?
JC.
Post by JC. »
I think the P6 box is a little bit longer than an LT77.
Image -JC.
v8saph
Post by v8saph »
JC. wrote:I think the P6 box is a little bit longer than an LT77.
by how much? will it still be ok to use :?
JC.
Post by JC. »
well its not got the best set of ratios in the world.
i did have a P6 gearbox and LT77 side by side at one point... I havent got the p6 box anymore so cant check for you... sorry.
Seriously though... the P6 box would be the LAST thing I would want to use. The changes are very sloppy for starters with quite a long travel.
Get yourself an LT77 or an R380 you will be so disapointed with a P6 box.
Image -JC.
v8saph
Post by v8saph »
thanks mate its all down to money this is a low budget toy with the wife moaning about cash being spent on it :(
JC.
Post by JC. »
bide your time!
I got an lt77 and v8 bellhousing + clutch bits for sixty quid.
Bargains are out there.
why not buy a couple of cheap ones on ebay and make one good one out of two or three?
Image -JC.
v8saph
Post by v8saph »
JC. wrote:bide your time!
its all a little confusing is the lt77 the box out of a sd1 is it the same as a range rover one can you ditch the transfer box what does the lt77 and r380 come out of
and as for making one i am not that talented :oops: :D
katanaman
Post by katanaman »
not really as there are a good few parts different so its not as simple as unbolting the transfer box. 2wd lt77 and r380's aren't just in an Sd1 though, they are in Sherpa vans for one which are common place in scrap yards. Gearstick position from one of them could be spot on for a Siera too.
v8saph
Post by v8saph »
is this any sherpa van and does the v8 bell housing just bolt up to it :)
katanaman
Post by katanaman »
don't know what the newest sherpas use but the older ones yes it will be either an lt77 or R380 and the bellhousing just bolts on. There are V8 sherpas though, ambulances and the like that are obviously straight bolt on.
v8saph
Post by v8saph »
does this apply for petrol and diesel :?:
katanaman
Post by katanaman »
yes
v8saph
Post by v8saph »
thanks katanaman :D
