You've checked the obvious things like the air filter?
Should be 1-2% CO.
RV8 MOT emissions fail, help needed
- SimpleSimon
- Knows His Stuff
- SimpleSimon
- Knows His Stuff
That being the case it as a small recessed screw/potentiometer on the Air Flow Meter in a recess on the exit side, you can see its housing right of this picThe Saint wrote:It's a '91 3.9 RV8 Range rover classic. It has no cats but has a full stainless exhaust system. I'm assuming the cats haven't been removed with the exhaust change.
