Changed the lt77 gearbox last year as the old one was a growler and I find difficulty in changing up from second to third when enthusiastically driven, no crunching of the gears what so ever, just does not want to engage third. This problem is only there when the revs are high and no difficulty at slower engine speeds. Got rid of the old pink oil and replaced it with new semi synthetic 5w-40, no difference in shifting.
Any ideas??
LT77 difficulty changing up from second to third
ramon alban
- Knows His Stuff
You could add molyslip!
as per pages 3 & 4 of the pdf available from here:
http://www.vintagemodelairplane.com/pag ... box01.html
If that does not work, check and renew if necessary the rubber bushes of the 'remote' assembly.
Perceived wisdom is to use original 'rubber' as opposed to recent trend towards 'poly'.
