Hotwire multiplug replacements?
sowen
Post by sowen »
I'm in the middle of fitting hotwire efi to my SD1, it's running and needs final plumbing and tidying. In the loom, the multiplugs to the stepper motor and water temp probe have broken, but not enough to fall off. Is there anywhere that sells new multiplugs, or is it a case of finding a good second-hand plug and splicing it in?
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
post a picture of the plugs.
The CTS connector is the same as the injectors ones - Junior Timer
http://www.vehicle-wiring-products.eu/V ... usings.php
sowen
Post by sowen »
DaveEFI wrote:The CTS connector is the same as the injectors ones - Junior Timer
Excellent, that's exactly what I'm after :D
Once I've got it running a bit better I'll be ordering a few bits from there, tidy up a few of the connections where they've seen some action over the years!
I've seen the stepper motor plug for sale too - probably at a MegaSquirt etc dealer.
Here we go:-
http://www.extraefi.co.uk/Misc_products.htm
sowen
Post by sowen »
Oooh you're s star!
Now I've seen kits are available, it's tempting to look into cutting the loom back a bit to fresher wire all round whilst losing all the dead wires I don't need, make it into a slightly neater installation in my SD1 8-)
The cable used on a hotwire (thinwall) doesn't tend to crack like the thicker stuff used on a flapper SD1.
sowen
Post by sowen »
Yes, it does appear to be far greater quality than the old flapper stuff I used to have, some of the wires I removed from the loom are still nice and flexible.
I've done a few little bits to the loom and installation and it now runs straight from cold with minimal if any hunting at idle, I now wonder why I never pursued hotwire in the first place! There's a few hardened and broken bits of insulation by some of the plugs which I'll sort at a later date with new plugs, for now just want to get some miles on it again :P
