Stem seals
paulsv8manta
Stem seals
Post by paulsv8manta »
Hi guys, I've just bought a set of SD1 3.5 EFI heads & have removed the the valves & noticed there are no stem seals. Is this correct? Are there heads without any?
If I should have them which type should I be looking at? As rimmers do a number of different types.
Cheers paul
There are heads without seals, but I suspect they predate the SD1 EFi. I believe that engine should have rubber washers on the inlet valves.
The later engines had a step in the valve stem and the modern lip-seal type seals. I don't know when they were introduced though.
Unless you need lip type seals to get through emissions I would not bother, they are just hassle to fit and get in the way of valve lift. Fit umbrella type on the inlets but really unless you have to don't bother with anything else.
ChrisJC wrote:There are heads without seals, but I suspect they predate the SD1 EFi. I believe that engine should have rubber washers on the inlet valves.
Thats right Chris. The pre SD1 just had rubber washers that ended up in nthe sump after not too long :)
Paul!
If your valve guides do not have the tops machined which leaves a short section of the guide with a narrower diameter you have two options. Get them machined and fit the later push on seals. Or you can get seals that look the same, but they fit over the larger diameter of the un machined guides. I have one here somewhere in a box that Gelmonkey sent me as a sample, but my workstation is a mess. I think it may be an Opel seal. Find Gelmonkey on here and drop him a PM.
But as Mike says, if the guides are in reasonable condition and the rocker gear isnt flooding the valve gallery you probably wont need them?
Perry
paulsv8manta
Thanks guys, really appreciate your time in letting me know. Decided not to use any valve seals & putting the money i saved towards a set of ARP head bolts.
Paul
paulsv8manta wrote:Thanks guys, really appreciate your time in letting me know. Decided not to use any valve seals & putting the money i saved towards a set of ARP head bolts.
Paul
ARP bolts ?? Or a stud kit ??
paulsv8manta
Hi mgbv8
Bought the 28 piece Stud kit. :D
You wont regret it. Especially if you pull it apart a few times to upgrade etc.
But dont fit the 4 outside studs. Or if you do just nip them up to about 30 ft/lbs. And make sure you use assembly lube between the washers and stud nuts when you torque them down.
Perry
pauldilley
Daimler engines 1966
Post by pauldilley »
I would like to know who and where I can get rebuild info and parts for the 2 V8 2500cc engines that I would like to rebuild . :?:
2500cc v8, which one? is it the Lancia mid '80s engine, it is basically the 308 gt4 lump with a bit of a de-stroke, fiat used the same lump in one of the late '70s coupes.
Maserati had a couple of 2500cc V8s but I cant remember in what apart from the dog ugly coupe from the mid 80's different engine to the fiat/Ferrari unit.
Coventry climax? mid '60s March?
Some clues please.
best regards
Darkspeed
Post by Darkspeed »
Clue is hidden in the title
Post subject: Daimler engines 1966
Buts a bit odd to post it in an unrelated topic
4.5L V8 Ginetta G27
Just me but the subject was stem seals. . . . must confess I missed the sub heading, being an old person little print just passes me by.
Haynes manual for the mk11 daimler
http://www.amazon.co.uk/Daimler-2-5-Saloon-Service-Manual/dp/185520875X/ref=sr_1_5?ie=UTF8&qid=1404674153&sr=8-5&keywords=haynes+daimler
or this
http://www.amazon.co.uk/DAIMLER-SALOON-V8-250-WORKSHOP-HANDBOOK/dp/B00556ZL4O/ref=sr_1_26?ie=UTF8&qid=1404674221&sr=8-26&keywords=haynes+daimler
best regards
