tow motor
bones
tow motor
Post by bones »
Hi all, im looking at getting a cheap 4x4 to tow my rover sd1 on a a-frame when needed. roversd1 is 3150lb roughly, what motor is legally able to pull it,and it has to diesel, all info welcome. :D rich
According to this, its considered a trailer and therefore needs to be braked if its over 750kilos. So is your a-frame braked?
http://www.direct.gov.uk/prod_consum_dg ... 200824.pdf
I too heard same thing A frame for emergency only and to tow vehicle to safe place to await recovery.
This is the reason why we bought a trailer.
r2d2hp
Post by r2d2hp »
See lots of motor homes towing cars with A-Frames. Wonder if they realise they are considered "Illegal" by the DVLA
But maybe they use use these which I would assume are legal
http://www.ebay.co.uk/itm/Motorhome-Tow ... 196wt_1399
JJMclure
Post by JJMclure »
Yep a framing requires the car to be braked but you can get a braking attachment that goes in the car and pushes the brake pedal. A bit Heath Robinson but there you go. Had to use when when I worked for a bunch of anonymous alchoholics
don't nibble on the barrel, pull the trigger!
bones
Post by bones »
Thanks for the replies, A-frame is not braked but that can be adjusted. Ive seen many cars using the a-frame and the cars they are towing have had no lights or interior fitted and most have been a rolling shell.Would like to get a trailer but funds are low :( . The use of a a-frame seems to be a black area,some sights say its ok as nothing is in law and others say its a no no. It just leaves me confused. :? rich
bones wrote:The use of a a-frame seems to be a black area,some sights say its ok as nothing is in law and others say its a no no. It just leaves me confused. :? rich
I would say in the past it was very much a grey area - but it seems to be far more clear nowadays.
bones
Post by bones »
something like that John ,but not a citreon :lol: . Next time i get pulled by vosa i will ask them. Not enough room on drive for 2 trailers. :) rich [/quote]
Return to “General Chat Area”
