correct carb for 5.2 stroker rover engine
andyv8van
Post by andyv8van »
Hi Guys,
i have just purchased a nice 5.2 rover engine etc, it has been run with a 600 holley , but i have not a lot of room above the block , so what carb would be suitable???????
i currently run 500 weber edelbrock carb
will a 600 edelbrock carb the answer
Andy
3.9 V8 Mini Van....THE BEAST
Rule of thumb is you take the engine cubic inch and multiply by the maximum RPM and divide by 3456. If you have an automatic transmission you will need a vacuum sec. carb, a standard transmission can use a Double Pumper carb.
This is for Holley carbs
So:
5200 cubic centimeter = 317cubic inch
317x5800= 1838600 / 3456 = 532 so a Weber 500 will do for normal use.
You can juggle the figures to suit your needs. But if you want good performance then fit a 600 double pumper and jet it down to suit.. You can tweak a 600dp to run well on a 3500 once you know how to set it up.
I use a DP (not vac sec) on my auto and its fine for race use.
This is by no means the be all and end all Andy but it gives you the basics..
Pel
sidecar
Post by sidecar »
Your inlet manifold is going to come into play here, I only have experience of two....
The Eddy Performer 180 is a good one but quite high, the Offy dual port is much lower but in my humble is not a good manifold. (V8 Dev reckon that they have seen a 30 BHP loss on big RV8 engines when compared to the Eddy manifold) :shock:
