My Dutton Melos
Posted: Sun Jul 10, 2011 11:08 am
I'm not generally the most organised person in the world and often forgetful, old age? so some things may be out of sequence. I bought my Melos last year, 2010, for the princely sum of £50, but what a mess it was. Unfortunately I didn't take any pics of what it was when I bought it but as I've been stripping it down/fixing I've started taking some, here goes.
No interior except for column and steering wheel
Rear wings extended by 2 inch each side to accomodate Scimitar axle.
Front wings were damaged and gel coat was cracked. Removed gel down to the fibre glass then reinforced underneath and a layer on top to fill the gap left by the removal of the gel coat.
One side done, just.
Next came the chassis, a Dutton chassis is poorly made as no jigs were used, just chalk marks on the floor. As the V8 didn't fit some minor alterations were needed which were simple enough. I had to cut some square tube out and replaced it with some seemless 1 inch tube 2 inches further forward.
This is it painted, bngs and waxoyl have since been inserted in the open tube ends.
[/img]
the front suspension has been replaced with some Spax that I had in "storage". New poly bushes fitted wherever a bush is.
That's it for now, will hopefully get some more pics up as I progress.
Andy
[/img]the front suspension has been replaced with some Spax that I had in "storage". New poly bushes fitted wherever a bush is.
Andy
