LT77 oil seal collar
Posted: Sat Jul 09, 2011 8:58 am
by marcjagman
Does any one know how to remove the oil seal collar on an LT77? I know there is a special puller needed, which I don't have, can anyone sugest a way to remove it or how to make something to remove it or even have the right tool I can borrow/rent?
Posted: Sat Jul 09, 2011 11:38 am
by bodger
if we are talking about the thingy that the thrust bearing slides on ...then just undo the bolts and a gentle tap will remove it .. and the rear seal is removable , just remove the output flange and there is loads of room to prise the seal out ...
Posted: Sat Jul 09, 2011 1:24 pm
by marcjagman
Output end. You need a puller to remove it. It's attached to the output shaft behind the rear casing, you can't remove the centre casing or anything else until you have removed the collar first. I need to change the input shaft.
Posted: Sat Jul 09, 2011 3:07 pm
by bodger
http://www.roversd1.nl/sd1web/index.html
does this help , i have stipped mine a few times and don't remember using a puller to do it ... are we talking about the output flange ? once you remove the centre nut that just comes off then remove the speedo drive and the 2 small plates on the top with the 10mm bolts holding them , once they are out you can then remove the rear case and the collar and speedo drive come off with it ... the collar on the shaft is not a press fit just drops on and is a spacer ...
Posted: Sat Jul 09, 2011 3:59 pm
by marcjagman
NO, it's called an oil seal collar and it's a press fit. The gearbox was originally from a range rover so it's got a different output shaft for the transfer box to attach to. Here
http://i422.photobucket.com/albums/pp30 ... 1265491217 and here
http://i422.photobucket.com/albums/pp30 ... 1265491244 and here
http://i422.photobucket.com/albums/pp30 ... 1265491283
Posted: Sat Jul 09, 2011 4:12 pm
by bodger
ah , now if you had said its a rangey one ...sorry about that ..
they are completley differant inside from the 2wd ones ..even though they have the same name ...ooopppss
any good ...
http://cgi.ebay.co.uk/large-GEAR-PULLER ... 5644393df1
Posted: Sat Jul 09, 2011 6:21 pm
by marcjagman
Thats the one, when I did a search all I got was those 3 legged things
