RV8 crossfire
Posted: Thu Jul 07, 2011 8:57 am
I am familiar with the recommendation for minimising the risk of crossfiring on the RV8 by separating plug leads 5 & 7.
However, when a wasted spark ignition is installed is it necessary to separate other leads? As an example, when no 1 is firing, no 6 is also sparking and no 8 is only 90 degrees from it's power stroke. So, should leads 6 & 8 be separated to minimise risk of crossfire.
During the complete wasted spark cycle other cylinders also follow close behind their neighbouring leads.
Anybody got any views or published info on this matter?
Cheers Denis
Cheers Denis
