Vibrations (probably not 'Good Vibrations!) LT77
Posted: Mon Jun 13, 2011 8:01 pm
Hi all - apologies for the poor title.
Just refitted my RV8 into my Capri. Its gained some vibration which may, or may not, be the gearbox.
Manual LT77 Rover with hydraulic clutch.
Symptoms;
Accelerate (not 'boot') & the vibration seems to be from the front of the car.
Decelerate (take foot off the gas) & vib seems to be at the rear.
Theories:
-When fitting the 'new' engine, we had to replace the brass spacer in the end of the crankshaft to fit the input shaft of my g'box as the one fitted in the 'new' engine was too big. Has this moved?
- Has something inside the box let go? If so, what?
Please could I ask for some suggestions before I pull the engine/box out for the 6th time in 2 years
Paul
Symptoms;
Theories:
Paul
