SD1 Back axle overhaul.
Posted: Tue Jun 07, 2011 12:07 am
by paulmanta
Does anyone have any data on how to set up an SD1 back axle after a complete overhaul ?
I am changing the diff bearings and the crown wheel and pinion and I could do with any tips, hints or OE data specs.
I think there is a crush washer in there too, any ideas where I might get hold of one ? Rimmers don't seem to have any.
Many thanks,
Paul.
Posted: Tue Jun 07, 2011 7:18 am
by john 215
Hi Paul,
The spacers have not been available for years :cry: I know a lot of people who have reshaped them over a bar of steel, not ideal but have not had any problems.
You will need a bloody big socket and spanner to undo the pinion nut and a method to hold it still, this is what i use, a ring spanner, a old SD1 exstention shaft a BMW M30 crankshaft locking tool !!
As far as overhaul req normal axle overhaul skills and tools,
A good friend has uploaded the workshop manual onto the tinter net, i can supply you with a link if that helps, it has a section on setting up and overhauling the 5 speed axle, same as SD1
cheers John
Posted: Tue Jun 07, 2011 11:16 am
by paulmanta
Hi John,
Thanks for that, the picture is exactly what I was after in terms of tips !
I will have a bash at reshaping the crush ring then, hopefully It will be ok.
A link to that page would be great if it is not too much trouble.
Many thanks,
Paul
