Page 1 of 3
Brake pipe and hose supplier
Posted: Tue May 31, 2011 12:00 pm
I'm doing a rear disc brake conversion on the SD1 And will need hoses and pipework to suit. Any recommendations for a one stop supplier? Where I can choose hoses by length and fittings rather than car make. And all the other bits too.
Posted: Tue May 31, 2011 12:46 pm
by Ian Anderson
Think automotive in Twickenham
Posted: Tue May 31, 2011 2:27 pm
by Eliot
automec - buckingham?
Posted: Tue May 31, 2011 3:26 pm
by Pocket rocket
Rally Design near Whitstable in Kent - they will make up braided hoses in whatever lengths you want.
Posted: Tue May 31, 2011 3:56 pm
by Coops
Caprisport in Didcot maybe able to help.
they have done the braided hoses on my car,
Posted: Tue May 31, 2011 7:27 pm
I was hoping to just choose off the shelf sizes. The calliper end needs a banjo, the other end to the pipe. The actual length isn't critical as I can make the brackets to suit.
Posted: Tue May 31, 2011 7:58 pm
by JSF55
lot of bike calipers use banjo fitting, nothing i know about, just something i've noticed
Posted: Tue May 31, 2011 9:21 pm
by gelmonkey
Hi Dave
PM sent to you.
cheers
P
Posted: Tue May 31, 2011 9:23 pm
by r2d2hp
Spectrum Hose in High Wycombe
Posted: Tue May 31, 2011 10:20 pm
You can buy the braided DIY stuff from a multitude of sources. It's fairly easy to do.
But strictly speaking all brakes hoses should be crimped. Not the DIY screw together stuff. Although I dont think Ive ever heard of any of them failing MOT ( but apparently they should )
Posted: Tue May 31, 2011 10:29 pm
stevieturbo wrote:You can buy the braided DIY stuff from a multitude of sources. It's fairly easy to do.
Wasn't intending making up the hoses. Just wanted somewhere that sold them by the hose spec rather than car model.
Posted: Tue May 31, 2011 10:35 pm
Most big retailers will be able to make to your spec.
Just decide what ends you want, hose type etc and they will make them.
Or anywhere that sells hoses really. There are quite a few now.
Posted: Wed Jun 01, 2011 6:14 am
by Mark
Posted: Sat Jun 04, 2011 12:30 pm
gelmonkey wrote:Hi Dave
PM sent to you.
cheers
P
Not received it...
Posted: Sat Jun 04, 2011 12:34 pm
I've not been able to find anywhere that you can choose hoses by length etc rather than car model, so making them up seems the way. Demon Tweeks seem to have all the bits and info from Goodridge- but seem very expensive. Any others do similar at better prices?
