Siamesed plenum. Again..?
Posted: Wed Mar 28, 2007 2:05 pm
by kokkolanpoika
Hi..
I just receive 2 plenums and trying to make siamesed plenum.
I´m thinkink if i cut those air "guides" away from inside the plenum. And weld the bolt holes stuck.. What are yuo think about that?
David Hardcastle book has got same kind modification..
Cut this "guide" away..
Posted: Wed Mar 28, 2007 2:54 pm
You might have problems sealing to the trumpet base in the central region where you have removed the fixings....
Posted: Wed Mar 28, 2007 6:39 pm
by kokkolanpoika
Do you mean that silicon sealer wont seal it for 4 bolts? :shock:
Posted: Wed Mar 28, 2007 8:33 pm
by Eliot
I think you are supposed to cut away the neck and leave the bolt part attached the plenum.
