LT77 Bellhousing options
v8trev
Post by v8trev »
Hi guys and gals
Quick question if I may.
Is there an lt77 bellhousing that will fit over an SD1 clutch assembly but has the starter motor mounting, and preferably the clutch slave too, on the left hand side (looking forward from the drivers seat)?
Ta :)
The starter is bolted to the block, not the bellhousing. I've never heard of anything different for the Rover V8.
v8trev
Post by v8trev »
Yes you are absolutely right. T'was a daft question - I will crawl back into the cupboard under the stairs now . . .
ged
Post by ged »
Hi Trev,
Never be afraid to ask daft questions because the day you do you stop learning.
Regards Ged
And for the slave, you could opt for a concentric slave ( one inside the bellhousing )
