EDIS coil connector
EDIS coil connector
Managed to break one of my EDIS 8 (4) coil LT connectors - the earlier type with the plastic arms on the side to lock it. Can find the later 'oval' type new, but not the earlier one. A good secondhand one would do.
Unless the later type fits?
- SimpleSimon
May be of help
Are you saying you need one? if so I can help you,pick up from SE London area FOC
Failing that, you can buy them here http://www.megasquirt-v8.co.uk/generic_parts.php
The pic on their site is of the later type which several sell. Unless I've missed something?scudderfish wrote:Failing that, you can buy them here http://www.megasquirt-v8.co.uk/generic_parts.php
They fit the Gen 1 coil packs a bit further down the page.DaveEFI wrote:The pic on their site is of the later type which several sell. Unless I've missed something?scudderfish wrote:Failing that, you can buy them here http://www.megasquirt-v8.co.uk/generic_parts.php
They are indeed for the early coil. But of a a different design. My original Ford ones have two plastic locking levers on the outside of the body - these use an sprung wire arrangement similar to the junior power ones as used on injectors, etc.scudderfish wrote:They fit the Gen 1 coil packs a bit further down the page.DaveEFI wrote:The pic on their site is of the later type which several sell. Unless I've missed something?scudderfish wrote:Failing that, you can buy them here http://www.megasquirt-v8.co.uk/generic_parts.php
They've changed since I bought some earlier this year as mine have plastic levers on them.DaveEFI wrote: They are indeed for the early coil. But of a a different design. My original Ford ones have two plastic locking levers on the outside of the body - these use an sprung wire arrangement similar to the junior power ones as used on injectors, etc.
Regards,
Yes - that's what confused me. I remember seeing identical ones to my originals on sale. And not knowing what the later coil used didn't help.scudderfish wrote:They've changed since I bought some earlier this year as mine have plastic levers on them.DaveEFI wrote: They are indeed for the early coil. But of a a different design. My original Ford ones have two plastic locking levers on the outside of the body - these use an sprung wire arrangement similar to the junior power ones as used on injectors, etc.
Regards,
Someone call
Ok
The lead ends I do at the moment are for the Ford Generation 1 Coil pack, obviously 2 x for a V8, these packs are noticebale as they have a "Collar" where the lead end goes on around 15mm from the top. This allows the 2 "Prongs" of the plastic Cage to Lock On to the ring, as thus, for the application I work mainly in (4x4 off road racing) these give a near 100% waterproof connection.
However I have supplied a huge amount of these to track cars and other engines, where peeps have switched to the old G1 coils over the later type, the later type has no ring and is just a Push fit at the coil end, this can and does not give such a "Locked on" solution, plus the early coils rarely fail (Pattern ones excluded from the prev statement !) - ie Buy second hand Motorcraft or Ford only.
Here is a pic of the units I have
The brass terminals - both sides for clarity, the 90 degree rubber boot, and the clip to lock in in.
These units will NOT fit the later smooth fitting Type 2, these use a completely differing system, and are indentifyable by a "Pin" in the centre and base of the insides of the output tower, not even the brasses above fit.
Hope this helps
Nige
Ok
Hope this helps
Nige
Lover of V8s and Megasquirt - Now with a shop for all things Megasquirt - & V8 - Brackets parts and complete systems www.megasquirt-v8.co.uk
- SimpleSimon
Oh......THOOOOOOOOOSE
As in :
Yes, I do these
Brand new genuine Ford (has Ford logo on them) hideously expensive IMHO
but not yet on my website - are £17 each, £15 each for here with Free UK P&P ?
Come with 3 x gromets and 3 x pins each and fit both types of Coil Pack units - PM me if you wnat them, esp at the price above,
DO NOT buy off my website even when I get around to listing them !
Nige
As in :
Yes, I do these
Nige
piccies ?
both of plug and coil pack ?
Nige
Nige
