Rover 3.5 + Bigas M84 vapouriser- mixture adjustment.
Posted: Wed Dec 29, 2010 9:46 am
Right,
So I have recently installed an innovate LC1 wideband lambda kit so I am for the first time able to see accurately what my AFR's are when running.
This is in a Landrover 90, running SU carbs and Megajolt. Engine is a stock but rebuilt 3.5 lump at 9.35:1 compression. Mixer ring on each carb fed from the vap with a closed loop mixer valve on the feed to these.
My problem is this:
I seem totally unable to get the air to fuel ratio to drop into the 13's when accelerating hard. Using the main mixture adjustment and winding this out pretty far only seems to give me a maximum of around 14:1.
Having the main mixture out this far has required that the idle screw is wound completely in so that it ticks over stably. AFR on tickover is currently around 11 as of this morning.
I have currently got the manual power/economy valve opened all the way, so this should not be restricting any draw the engine may be putting on the vaporiser.
Cruise AFR's are fine as they are controlled by the oxygen sensor.
So- any ideas on how I can get the WOT AFR richer without my idle AFR getting worse?
Things I have checked are:
LPG filter- clean (only a couple of thousand miles old)
Checked for heavy ends- barely any at all.
One thing I have yet to check is what the stepper motor does on the motorised power/economy valve when open loop. It is currently set to go open loop at idle to prevent hunting. I have been assuming that it would just wind out and open fully, but i guess it could just centre itself which would restrict the suck that the vap feels on acceleration when taking off from stationary.
Failing any surprises with the closed loop system, the vap has done at least 30,000 miles without a rebuild- could this be causing my issues, or is it just down to me needing a better/different vap unit?
Thanks all
My problem is this:
Thanks all
