Got no gears !!!!!!!!!
wwfc_1974
Post by wwfc_1974 »
Finally got engine running but can`t select any gears, have heard of this happening before so if anyone can give me a bit of advice it would be greatful.
Series 3 Land Rover with 3.5 V8 Rangie engine on standard series box.
Chris
1982 Series 3 88" V8
Most obvious one, would be the clutch isnt releasing ?
Or if it feels ok.....dodgy gear linkage or something ?
Perhaps clutch needs bled.
wwfc_1974
Post by wwfc_1974 »
did bleed clutch before I put engine in but not sure if I got all the air out, will do it again to be sure
JC.
Post by JC. »
Can you engage gears with the engine off?
Image -JC.
sowen
Post by sowen »
Sounds like what happened when I fitted a v8 to my series 3. Have you taken the little cover off the bellhousing on the front of the gearlever to see what the clutch is doing? Does the clutch pedal get solid by the time it reaches the floor?
I found that my release arm was not being pushed far enough forward by the slave cylinder because it was hitting inside the bellhousing. I guess this is because the adapter ring is desingned for the older crash box which has a boss on the clutch diaphragm. I had to pull the engine back out again, and make the release arm pivot about half inch longer to get the clutch to work and select all gears. Hope this helps.
Simon
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
wwfc_1974
Post by wwfc_1974 »
was going to take inspection cover off yesterday but it p***ed down all day. can get reverse with engine off but it`s a hard fight, thought it might be something to do with the release bearing not travelling far enough forward.
oh well, engine out again !! :cry:
thank
Chris
