bmw v8 swap
Posted: Fri Aug 20, 2010 4:23 pm
by dabber
any info on swapping 4lt v8 from 540 e34 into 316 compact e36.thinking bout doing this for winter project.engine mounts crossmember clearances etc thanks. :)
Posted: Fri Aug 20, 2010 7:04 pm
I remember it being done by one of the german tuning houses a few years ago, because I saw the result at a car show. but I suspect it was a pretty big job as the resulting engine bay looked very full :shock: . Might be worth a google but I have no further information.
Posted: Sat Aug 21, 2010 8:48 am
by dabber
thanks.i know alpina did this,parts still available but approx 1600 quid for engine mounts and modified sump.want to try and do this on a budget.got the compact will start looking for a donor 540,and take it from there. :)
Posted: Wed Sep 15, 2010 12:24 pm
by Will Reeve
I would look for an non-vanos 4.4 from an early E39 or E38, no bore problems with these and more power :-)
Posted: Mon Sep 27, 2010 6:10 pm
by Gibson
Hugeeeeee swap. I looked into in detail before going TVR v8 with my E36.
The basics are.
New sump, new oil pickup, new exhaust manifolds, transmission tunnel modification, relocate brake servo.
Something other stuff but a pain in the arse....
This was much easier
Posted: Thu Sep 30, 2010 9:17 am
by Will Reeve
That's an interesting exhaust....where does it exit?
Posted: Thu Sep 30, 2010 9:34 am
by Gibson
Its from the TVR and it runs down the nearside of the sump/block which is great because the offside of the block is really very tight for access with the steering column....
Posted: Tue Oct 12, 2010 8:45 pm
by dabber
thats pretty cool where did you source the engine from what else did you need to fit it. :D
Posted: Tue Oct 19, 2010 8:03 pm
by Gibson
Bought it from a friend of a friend who does finance repossesion who broke the car for spares. needed to modify the sump, make my own engine and gearbox mounts, new prop, radiator needs moving into the boot because of the exhaust manifold, fitted a gearbox remote from an SD1 instead of the TVR one....
The normal really for a rwd engine conversion.
Re: bmw v8 swap
Posted: Tue Oct 19, 2010 11:17 pm
dabber wrote:any info on swapping 4lt v8 from 540 e34 into 316 compact e36.thinking bout doing this for winter project.engine mounts crossmember clearances etc thanks. :)
Think there's a major problem with sump clearance with R&P steering/cross members. The E39 6 has R&P steering - the V-8 a steering box. IIRC, due to the oil pump position in the V-8.
Re: bmw v8 swap
Posted: Wed Oct 20, 2010 7:35 am
by Will Reeve
Thats correct, even the M5 has the 'box! I think Alpina (or was it Hartge) managed to squeeze a V8 into a E36 didn't they?
Posted: Wed Oct 20, 2010 6:49 pm
by Gibson
Alpina did one.... but the parts will cost you three times as much if not more than a clean E36....
